HSS Corner Radius
4
HSS Corner Radius
HSS Corner Radius
Does anyone have a chart listing corner radius's for HHS rectangular tube steel?
RE: HSS Corner Radius
Check your AISC manual (assuming USA) - pretty sure it’s 2 times the wall thickness as an estimated radius but does vary.
JAE is in the ball park. See quote below.
Quote:
The corner radius of Hollow Structural Sections (HSS) is not something that can be manipulated to order, and is part of the existing manufacturing paradigm of numerous HSS producers in North America. The typical outside corner radius of North American HSS is 2t, where t is the wall thickness of the as-produced HSS, to the standard ASTM A500-10.
From CISC: LINK
AISC 360-16 Section B4.1b.(d) specifies that for local buckling of HSS members, 'b' and 'h' shall be taken as the outside dimension minus 3t, if the corner radius is not known. That implies an outside corner radius equal to 1.5t, where 't' is the design wall thickness.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
