I've been looking through TRUSTEEL manual by Alpine to get some guidance on typical max spans by cold formed trusses. In their material, they have trusses that can comfortably span over 80 feet with no mention of internal bearing locations. I've always had the mindset, due to past mentors, to place internal bearing points for trusses at about max spacing of ~60 feet. I'm trying to see if that is just an outdated rule of thumb with the advancement of truss design or if there is solid justification for that internal bearing recommendation.
Does anyone have any experience of designing trusses with longer spans (+60 feet) and no internal bearing? Any concerns of special inspections I may be skimming over? I have a technical request into a manufacturer, but figured I'd ask here as well. I place their response when it comes in
