Amada Rotary Index issue 1
LaserMark
Has anyone had experience with the FOMII3015RI rotary index. I am having and issue with getting i to automatically shuttle the index table in. I can do it manually but that is not the way it should be. I get an error code "EX0222 LST not in lower position" but all my lights are on for the LST table.
Have you checked so no sensors are loose or if any of the "static" locks are loose.
And if there is any cut loose parts that are jamming in somewhere inside the LST table.
That was a good thing to check I found it to be something else. It must be in memory mode when you put last into lowest position.
