Flash Method in HTRI Heat Exchanger Modeling for fluid properties generation
Hi All,
Can someone please explain on what conditions should Differential and Integral Flash methods are to be applied for Heat Exchangers modeling in HTRI software?
For one of the exchangers modeling, when I applied Integral Flash method, I was not getting 30 Temperature points. Then I changed the Flash method to Differential method and then I got all 30 Temperature points. Why is it so?
