Contact US
Accurate temperature measurement
Hi
We have an application where we need to measure temperature of the filling in the steel container.
We cannot have a direct temperature sensor placement in steel Container due to application constrains. SO we planned placing it as shown in figure.
Could you please suggest if this type of arrangement would give accurate measurement?
if not, can you suggest a way to place the temperature measurement sensor so that it can read the temperature accurately?
Thankyou
RE: Accurate temperature measurement
Why not? Please explain. Is this for school?
Is the temperature sensor in contact with the steel container? You've again picked a measurement approach that requires calibration, which will probably cost your more time than if you did it the conventional way.
TTFN (ta ta for now)
Yes, the temperature sensor is in contact with steel container.
This is not for school.
What temp range?
What accuracy and precision is needed?
What kind of sensor will you use?
In general the sensor needs to be as light weight as possible without sacrificing durability, and fastened very well to the surface. If using a TC it should be spot welded to the surface, if a TRD it should be glued using a thin adhesive. Then the outer insulation needs to extend over the sensor to minimize local heat loss.
P.E. Metallurgy
Edstainless
temperature range : 15 to 85 degree C
Accuracy : +/- 1 degree
Precision : 0.5 degree C
as of not we planned to go with digital temperature sensor ( LM75B)
Radiation will never be accurate enough at your temp range. Too little energy to work with. Any little change in surfaces (color, shininess, reflectance, emmisivity) or even in ambient air will impact the reading.
I looked at some rated for -20 to 100C and they were still +/-1C on both accuracy and precision, and you have to figure out how to set the emissivity.
https://www.advancedenergy.com/globalassets/resour...
If you want that accuracy and precision then both values for the sensor will need be better than 0.2C, because you also have the meter to account for.
Use a contact RDT. Typically a 3wire one is used for high precision and stability. You can clamp them in place and use some heat conducting paste and get very good results.
P.E. Metallurgy
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
