CN7M casting to Alloy 20 Pipe - 1-1/2" Sch 40: Welding Procedure
We have a weld procedure for P45 to P45 material that has worked fine, but recently had an issue with 1-1/2" socket weld fittings made from cast CN7M.
Some of the castings developed pinhole leaks near the welds in the heat affected zone.
Hydrotest, air test, visual, and dye penetrant examinations prior to welding found a few issues, but nothing seemed to correlate to the crack development.
A welder with experience on these materials increased preheat to 150°F and issue the issue seems to have been resolved.
Not being a welding engineer, I wanted to find out:
- Is elevated preheat recommended for all P45 materials?
- Or for CN7M castings in particular?
Thanks.
Thanks.
RE: CN7M casting to Alloy 20 Pipe - 1-1/2" Sch 40: Welding Procedure
Did you encounter hot cracking or other defects/cracks? What filler? Depending on a.o. the Ni%, either ferrite number or heat input should be carefully predicted/applied.
Should be kept - very - clean before/during welding!
These alloys in general and a 0 FN, which makes them very susceptible to hot cracking.
A little pre-heat can help and it shouldn't be an issue with the metallurgy.
It is more common to address this with controls on the heat input, weld speed, inter-pass temp, and cooling rate.
Allowing stresses to build during welding nearly guarantees cracking.
Castings can be problematic because the microstructures can vary.
P.E. Metallurgy
EdS raises relevant points, to which I would add: was the casting sound to begin with?
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
The customer of ours with the issue sent his GTAW WPS. It specifies ER320LR, F#45, A#N/A(non-ferrous) and .030 to 3/16 filler metal with a 60°F preheat temperature.
As I noted, I'm not a welding engineer, but in my limited experience it seemed off, starting with "non-ferrous".
Checked vendor data: F6 & A9. Confirmed with a copy of Section IX.
We had one of our shop welders visit - he observed #1 - they were welding it cold, with no preheat - January in New Jersey cold.
#2 they were laying the wire down hot and doing a single pass.
He worked with them and made some successful welds with 150° preheat and 300° max interpass in two passes.
I also did some internet searching and found good information in a publication by the Nickel Development Institute.
It notes that some cast grades "such as CN7M" are fully austentic (i.e. 0 FN as EdStainless pointed out) and goes on to state that special techniques may be needed to prevent microfissures next to the weld.
Pretty spot-on for what we saw - pinhole leaks after welding in the heat affected area.
And the end of that paragraph say "Techniques available are low interpass temperatures, low heat input and peening of the weld to relieve mechanical stresses." Our experienced welder doesn't know the metallurgy, but knew to start warm but don't get it too hot.
I'm getting someone to create a formal WPS for our shop.
