Regarding Hypoid gear set design
Anupam_Terero
1
I have been working on this hypoid gearset design for a cable-pulley system, and have two questions regarding that.
1. I need to calculate the tooth load components. However, the gear design firm, Gleason corp. has only provided the axial and separating forces. The separating force will have further 2 components, radial, and tangential forces. I have attached the gearset dimension files.
Can someone suggest how to calculate those components?
2. The winch is driven by a hydraulic motor which is directly coupled to the pinion and the gear output shaft is connected directly to the pulleys. Once the motor is stopped, the tension in the cable increases to more than the load for which the gearset was designed. The load (after reduction) however is still lesser than the motor's capacity, so the motor holds. So, do I need to take this static load that goes on the gear without any rotation into consideration for the gearset design?
Would be really grateful for any support in this regard.
 https://files.engineering.com/getfile.aspx?folder=8084fec7-0404-4cff-92ce-b6cb0f970e64&file=5X76_GEMS_DS.pdf
