API-650 Tank External Pressure
I'm evaluating an API-650 tank for external load, snow and external pressure.
The equations (V.7) are
DL + (Lr or S) + 0.4 Pe or DL + Pe + 0.4 (Lr or S)
My tank has a continuous 6" w.c. vacuum applied to it. When looking at the above loading conditions I'm replacing the 0.4 factor with 1.0 since in my mind the tank is always operated at the maximum external pressure, and could potentially see maximum snow loading in conjunction with the maximum external pressure.
Looking for a peer check,agree?
Thank you
RE: API-650 Tank External Pressure
Adjusting the factor upwards if necessary make sense.
However, if it is always operated at that external pressure, then the design external pressure should be some higher value.
There would normally be some margin between operating pressure/vacuum and set points on the relief valves, and then some additional margin beyond the set points to generate the required flow rates. Check the definitions and see which of those values is the "design" value.
You could potentially have situations where the tank is never under vacuum when completely empty, or never empty at maximum wind speed, etc., and those situations may not be addressed by the standard.
JStephen, Thanks for the feedback. Just looked through Addenda 2 of API. Seems like they caught this too. The 0.4 factor got replaced with a variable Fpe which
"is a modifier for the design external pressure when used in load combinations with other variable loads. Value equals normal operating external pressure/design external pressure or a minimum of 0.4. Manufacturer to use 0.4 when not specified. (See 5.2.2.)"
Note: I think they mean that the value of Fpe*Pe shall be equal to the normal operating external pressure. Since Fpe is just a coefficient
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
