Urethane seat and aflas seal
gguliye
Industrial
GB
Hi
Does anyone have any ideas why we can't choose the urethane main valve seat with aflas seal for 453 pilot valve from Anderson greenwood ??
You can use those materials for the 453. Depends on the size, pressure and temperature. Is the sizing/selection program not allowing it?
Per ISO-4126, only the term Safety Valve is used regardless of application or design.
No
the program says they can not be chosen together.
i dont know the reason why. Temperature/pressure limit allows it
regards,
I'd call/email Emerson/Anderson Greenwood and ask. PLease let us know.
Good Luck,
Latexman
If not together, why not just select the superior one? I guess its just a BOM thing the program is giving you. As Latexman says, just ask the vendor. Let us know for reference.
Orbutrator
I have to give like to like one. I asked the factory and didn't receive any answer yet
Patience, it's the holiday season. They'll revert.
Good Luck,
Latexman
it is possible.
however, not in the standard option
regards,
