H.Kroon's method
H.Kroon's method
RE: H.Kroon's method
Apparently the attachment is a copy of a page from a book . Unit of P1 is N/mm or Lbs/inch. Kroon’s method is not addressed in API 650, BS EN 14015…and I did not see in any calculation report .The width of annular plate is suggested with different formulas…I checked the spreadsheet and;
Po=Liquid pressure at the bottom = 0.9* 9807 N/m3 *16 m= 141221N/m3 =0.1412 N/mm, = 20.47342 lbs/ inch2=
P1=Weight of shell + portion of roof supported by Shell/ Perimeter length = 97.63 lbs/ inch = 17.1342 N / mm
P2 =Liquid pressure on inside fillet weld=0.3150*20.47432 =6.44831 lbs / inch = 1.1317 N/mm
This looks like a partial screen grab of chapter 3 entitled "Ambient temperature storage tank design" from Storage Tanks & Equipment, page 49 figure 3.37 "An example of H. Kroon's method for tank bottom annular plate analysis".
To calculate P1 in N/mm you add the total weight of the tank shell plus the weight of the portion of the fixed toor supported by the tank shell and divide that sum by the circumference of the tank, all using the proper units.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
