Adaptive meshing after using Hypermesh
I want to perform Adaptive remeshing on my model, which I created in the Hypermesh and simulated in Abaqus. When I am trying to do that in Abaqus CAE, It is giving error that "Orphan Mesh are not allowed in remeshing".
looking for help! Thanks!
RE: Adaptive meshing after using Hypermesh
When you import mesh created in external software to Abaqus it’s imported as orphan mesh (without associated geometry). Such mesh can’t be refined in regular way. So you have to import the CAD model of this part and perform meshing in Abaqus or, if you have such CAD model and the geometry is relatively simple, use Geometry Edit —> Face —> From element faces to replace orphan mesh with underlying geometry (and then mesh it in Abaqus).
thanks @FEA way !
so it means the adaptive meshing functions could be used only after meshing within abaqus?
Yes, adaptive remeshing feature works only with native meshes, i.e. those created in Abaqus.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
