Energy norm command in Abaqus
How do I get the energy norm in Abaqus ?
RE: Energy norm command in Abaqus
Abaqus provides some error estimates (here called error indicators) as output variables for implicit analyses. However energy norm error is not available. You would have to operate on field output data in Viewer or use scripting to get additional output like that.
If you are thinking of the energy norm as an implicit solution control, then Abaqus/Standard does not offer it. It's a weak criterion that is easily fulfilled so some codes do not bother putting it out there. I haven't used Abaqus in a few years so things may have changed.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Addressing Tooling and Casting Requirements at the Design Stage
Several of the tooling and casting requirements of a part can be addressed at the design stage. If these requirements are not addressed at the design stage, lot of time is spent in design iteration when the design reaches the die caster. These design issues lead to increase in time and cost of production leading to delay in time to market and reduced profits for the organization. Download Now
White Paper - The Other Side of Design for Assembly
Assembly level constraints need to be satisfied before the design can move downstream. This white paper will go through the various assembly level issues, which need to be tackled by various organizations on a regular basis. Know more about DFMPro, a design for assembly software. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
