Nominal tank diameter in 5.6.1 API 650
Dear all,
What does the nominal tank diameter in 5.6.1 represent? IS it INSIDE Diameter OR OUTSIDE Diameter of tank?
RE: Nominal tank diameter in 5.6.1 API 650
Usually, the tank diameter will be a rounded number (120 feet or 18 meters or something) and that is the nominal diameter. It may be the ID or OD or at centerline of plates. See Annex L.4 and Section 5.1.5.3(b). This may be addressed somewhere else, but I'm not seeing it at the moment.
I found out in section 5.6.1.1 that unless otherwise noted it is the centerline diameter of the bottom shell courses plate. But in Annex F, figure F.2, Rc is given as inside radius of tank shell, can we use nominal radius(nominal diameter/2) in this case?
For design it's a meaningless difference between 100' centerline diameter and 100' inside diameter. On a 100' tank with a 1/2" wall the difference is D=100.00' vs D=100.04'. This won't affect ordered thickness, App F required area, etc. I'd use D=100.0' for both cases.
However for detailing and construction it can be important. On the same tank if you detail it for 100' centerline, but build it 100' inside you'll have a 1.5" gap at the final vertical weld.
Thank you, Geoff13.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
