Non-triangular steel bracket
Yousef ZAA
58
Dears,
I have a non-triangular steel bracket, and could not find a refernce in the AISC for its design, only the the triangular case is addressed, could you guide to some references to the non-triangular steel bracket.
Thanks.
I don't understand your problem ... maybe sketch would help.
But generally you can design everything by using 'engineering' methods....not everything is given in design guides....
Yousef,
I don't see the problem. You have a bearing plate supported by a gusset. The gusset (and connection to the member on the right side of your image) will be expected to resist a shear and moment. So the gusset will be in flexure - think of it as a very short cantilever - and shear. Based on the shape shown, it seems likely that the gusset is as deep as it is because the length of weld connecting to the member on the right probably controls if the desire is to use a pair of fillet welds or small PJP welds for the connection.
Yousef,
For the bracket, it is to be designed using the method explained in section 6.6.7 of PCI manual, 7th Ed. This was taken from the Salmon book,
Salmon, Charles G., and J. E. Johnson. 1996. Steel Structures: Design and Behavior. 4th ed. New York, NY: Harper and Collins.
