Creating a SID_FEM with Abaqus
Hello everybody,
At this time I am trying to change a .SIM file into a .SID_FEM file with Abaqus. I need this type of file to simulate structures in Modelica. I hope there is somebody on this forum that has experience with this.
I tried two different methods to create those .SID_FEM, but until now I didn´t have any luck.
1. The first method is with the cmd prompt. First I should write in the input file ",FLEXIBLE BODY=S" next to *SUBSTRUCTURE GENERATE. Then I should write "abaqus tosid -job <jobName>" in the command prompt. Unfortunately I get the error "Abaqus Error: Command line option "tosid" may not be used with "analysis" every time. Am i getting this error because I am using the 2019 Student Version of Abaqus Or is there another mistake i am not noticing? I have included my input file to this post.
2. I have also tried writing the line "*FLEXIBLE BODY, TYPE=SID" in the SUBSTRUCTURE part of my input file. This method is decribed at: http://bobcat.nus.edu.sg:2080/English/SIMACAEANLRe.... In the corresponding paragraph is actually written that the SID data is saved in the .SIM file of the substructure. The data should then still be written to a new .SID_FEM file with a program. Maybe this could still be possible with another feature of Abaqus I don´t know about yet?
Thanks and have a good day!
RE: Creating a SID_FEM with Abaqus
Use the following keywords in the input file:
*Step
*Substructure Generate, mass matrix=yes, recovery matrix=yes
*Flexible Body, type=SID
*End Step
In the command line interface you have to use: abq tosid -job <jobName>
Thanks for your quick reaction. I tried out quite a few things but so far nothing is working.
I have the feeling that the problem could be caused by three different things:
- using the CMD Prompt/ Abaqus in a wrong way
- Having the Student version that is not allowing me to use the "abq tosid -job <jobName>" command
- having errors in my Input file.
I have included a picture of the error messages I get in the cmd prompt and the error I get when using the Command Line Interface in Abaqus/CAE.
Also I have copied the substructure generation part of my Input File to this post to check if it is right.
Can somebody recognize which mistake i am making?
*** Part of the Input file: ***
** STEP: Step-1
*Step, name=Step-1, nlgeom=NO
*Substructure Generate, overwrite, type=Z1, mass matrix=yes, recovery matrix=YES
*Damping Controls, structural=COMBINED, viscous=COMBINED
*Retained Nodal Dofs
SIDENODES, 1, 3
*End Step
It's possible that student version can't do this but first I would make sure that the specified name of the job in this command (job_Z1) is exactly the same as the one of .sim file. Also try the following syntax:
abq2019 tosid job=job_Z1
If you installed any hot fixes the first part might be different (for example abq2019hf4 in case of Abaqus with installed Hot Fix 4).
i finally managed to create the .SID file. I discovered that the student version does not support tosid. Also the command abq turns out to be an old command.
What worked for in the end me was using "abaqus tosid job=job_name" in the cmd window while using an official version of Abaqus.
The job_name file has to be a .SIM file of a substructure and has a name like job_Z1.sim.
To find out which command you need you could look in the folder: C:\SIMULIA\Commands and then the name of one of the files there should work.
Thanks for the help!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How to Capitalize on HVAC/R Trends to Drive Business Growth
According to Steve Yurek, CEO of the Air Conditioning, Heating and Refrigeration Institute, the HVAC/R industry is facing change on all fronts. This includes challenging trends on contractors and distributors like new refrigerants, growing automation, complex sensors and monitoring, green initiatives and a technician shortage. We look at these trends and outline actionable insights on how it all can be turned into a competitive advantage and business opportunity. Download Now
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
