Fellow structural engineers!
I have a residential custom home that requires a topping slab to accommodate the drainage system. Between the interior and exterior space, I am dropping the composite steel decking by 4" and allowing them to add a topping slab to slope to drain.
I am faced with a challenge in terms of assuming the right amount of dead load for the topping slab.
Since the topping slab will be sloping, I am not assuming 4" thick additional topping slab. Rather, I am finding the average between the minimum thickness and the maximum thickness of 4".
The question are:
What would be the minimum thickness required for a topping slab?
Is NWC preferred for a topping slab that is exposed to water?
Any thoughts or recommendations would be helpful.
Thank you.
The question are:
Thank you.
