We have a floor that experienced the attached cracks. It is a 100 year old clay tile system where they used 8" tile and 2" of topping which created the 10" total depth concrete T-beams as shown on the joist load table diagram on the attached file. The T-beams are spaced at 17" on center and are about 5 inches thick at the bottom. The T-beams have the attached reinforcing at the bottom and top at the ends on the attached original drawing I recently found.
The bottom of the floor did not show any damage from overloading in any areas, only some rust damage. They drilled a couple of locations in the top of the slab and the cracks went an inch or a slightly more deep, but I can't say for sure the cracks don't extend down below the topping and into the beams at some locations. The cracks are not something that have been there for years. These appear to be yield line type cracks but the pattern does not meet what I would have expected for a one-way slab, unless the top temperature bars altered the yield lines? Also, there was no spalling off of the top concrete from compression that I am aware of and none of the bottom of the beams were cracked. There is an adjacent existing room that have similar but old topping cracks that have been worn down from rolling cart traffic. Any thoughts on the attached crack patterns?
