ONENGINEER
Geotechnical
After going through a number of references I found ambiguities on the dimensional equations. While ks = p/y should be in kN/m3 form, sometimes it is stated as kN/m2. In some references it is given as Ks =ks.x which makes a good sense but this is not consistent. Also modulus of subgrade reaction is sometimes called coefficient of sub-grade reaction with the same dimensional equation. One would expect a coef. be dimensionless. Also did not find a relationship between horizontal and vertical (coefficient of) subgrade reactions. The ks value is used for horizontal subgrade reaction, making the terms “horizontal” and “coefficient” redundant. So would there be a horizontal, a vertical and a resultant modulus or coefficient?
ks is sometimes shown as kc, the latter I think is for cyclic (instead of static) loading (or is it for clays compared to ks for sand.
Could one of the experts shed lights on the above, if possible. Thanks.
PS: this is my second active thread and hope it would be acceptable to the site admin to have two at a time. Thanks again.
