L-Flange bolted connection
I am looking for a reference in English which would contain formulas required to check following L-Flange connection (please see picture below):
Do you have any and may share?
Regards!
RE: L-Flange bolted connection
Any steel design text book shall have examples on this. Assume the applied force is T, the resulting bolt tension Tb will be larger than T for equilibrium, and prying force, if any.
AISC Steel Construction Manual, Chapter 9 - Prying Action (starts on page 9-10 of 15th edition)
retired13, if you are aware that some of the books you think of, contains that particular connection it would be truly supportive if you could share the name and authors of this book.
As dauwerda, the first comes to mind would be AISC steel design manual. For excellent steel design textbook, I would suggest authors Charles G. Salmon and John E. Johnson, with emphasis on earlier books by Johnson. I suggest to checkout some steel books from college library, and focusing on prying action. The examples may not be exact as shown in your opening inquiry, but the theories and thinking remain useful.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
