Im new to this. We are having a discussion in our office in a field were not very experienced in. If a plate test was carried out with a 450mm Plate or 600mm Plate, for ground which requires 100kn/m2 load capacity, what should the plates be tested to including a standard UK factor of safety?
Thanks.
Thanks.
