Shear Modulus G
Shear Modulus G
Shear Modulus G
What is the use of the curves for G/Gmail against the shear rate? Thanks
RE: Shear Modulus G
Which curves? Can you post a reference
RE: Shear Modulus G
shear modulus is not linear. Low strain modulus and high strain shear modulus differ. The graphs show that difference.
f-d
ípapß gordo ainÆt no madre flaca!
RE: Shear Modulus G
Do you mean G/Gmax (just tried to autocorrect it to mail for me so I take it you are!)
f-d is right.
That graph shows that the more strain you have the less stiffness you get.
Retaining walls are typically small strain problems and they benefit from using small strain stiffness. For example in plaxis you can use the hardening small strain model (HS small). You select the strain rate, for example 0.001. As your strain increases it uses your shear modulus (0.7 x Gmax) to a strain of 0.001 to determine deflections. After that it uses your standards Young’s modulus to determine deflections.
RE: Shear Modulus G
Look at Google for "Modulus of reduction curves". These curves are used in geotechnical earthquake engineering - site response analysis.
Also, agree with f-d and EireChch...
What will be the application?
RE: Shear Modulus G
Thank you all for your replies and my apology for mis-autocorrection. G/Gmax against shear rate was intended as you guessed correctly. There are usually two curves and wonder if this is a range or two different cases.
I am familiarizing myself with soil dynamics with no special application.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Research Report - How Engineers are Using Remote Access
Remote access enables engineers to work from anywhere provided they have an internet connection. We surveyed our audience of engineers, designers and product managers to learn how they use remote access within their organizations. We wanted to know which industries have adopted remote access, which software they are using, and what features matter most. Download Now
eBook - Managing the Context of Product Complexity Using the Digital Twin
Keeping track of changes to complex products is difficult—think Aerospace & Defense equipment, new generations of commercial aircraft, and software-based automobiles. A new way to managing the digital context of the physical product is required and the answer is the Digital Twin. This ebook explores the opportunity available for Operations and Maintenance for the Digital Twin. Download Now
White Paper - Trends in Industrial Filtration
Substantial progress has been made in filtration technologies in recent years. New filter media materials, designs and processes have led to filters that are more efficient, reliable, compact and longer lasting. This white paper will discuss the various trends that are impacting operational responsibilities of MROs today and the resources that are available for staying up-to-date on the latest filtration solutions. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
