How to calculate "Minimum width of saddle at top" from Moss Pressure Vessel Design Manual
I've read Moss Pressure Vessel Design Manual about design of Vessel's Saddle. To calculate minimum width of saddle at top, Moss suggest to use formula like in my attachment. But the problem is, what is Fb and h ?
Moss said that Fb is allowable bending stress, how I get it ? is it same with allowable stress ?
and how about h? Moss didn't said anything about it or did I miss something ?
Thankss
formula from Moss Pressure Vessel Design Manual, procedure 3-11, page 179.
RE: How to calculate "Minimum width of saddle at top" from Moss Pressure Vessel Design Manual
Usually for the support structures the value used for Fb is 0.6Fy, this is based on AISC Manuals, if you take a look on other procedures on the same book you will find some information about this.
Can't help you with the h dimension though.
Victor
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
