floating foundation welded with flo
floating foundation welded with floor. see the pic?then ]hat is the duty of spring. i found in a new installation. is it wrong???
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: floating foundation welded with flo
The welding looks non OEM.
I'd inquire about the back story.
It may be that the isolation mounted equipment installation did not perform as well as expected .
It would not be the first time.
Is a fan the main rotating equipment on the formerly sprung foundation?
Walt
