pad lugs Ring Girder .
Aloni
IL
Hi to all,
I need to design a stainless steel pressure vessel with carbon steel lugs Ring Girder .
Usually when design lug on a vessel it is possible to add a pad,
But in lugs Ring Girder I cannot find any guidance how to calculate the pad.
I have search Bednar
I use compress and pvelite, both of them doesn't have the option to add a pad to lugs Ring Girder.
Design condition -1+6 barg @200°C. Total weight include external loads is 35 ton
Ill appreciates some guidance how to calculate the pad.
Aloni
