Contact US
ETABS Automatically Generated Seismic and Wind Forces for Checking
Hi Sirs,
Is there a way to retrieve the seismic and wind forces automatically calculated by ETABS and how they are distributed vertically and horizontally throughout the structure? I prefer forces plotted in the model using arrows but if there is none, forces in table format will do. The purpose for this is so that I can verify that the seismic and wind forces generated by the program were applied correctly.
By the way, the version I am using is still ETABS 2016 version 16.2.1 Build 1727
Thanks! Any help is appreciated.
RE: ETABS Automatically Generated Seismic and Wind Forces for Checking
You can view forces in tabular format using Display > Show Tables (ctrl+T). In there you'll be able to search for the relevant loads you're after.
You can also display them visually by Display > Load Assigns.
Thanks Trenno! Display > Load Assigns > Joint is what I am looking for. So you can only see your generated forces when an analysis has already been run.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
