the sets in inp.file
I have defined partitions of plate with different materisls, assigned into two elsets and saved in inp. file.
But when I imported the inp.file, there is no materials properties and sets that I defined in the inp. file.
Need helps!
Thx a lot!
attached olease find my Inp.file
https://files.engineering.com/getfile.aspx?folder=...
RE: the sets in inp.file
So you created part, partitioned it and meshed it in Abaqus/CAE and exported .inp file. Then you defined sets, added material definitions and sections with these materials assigned to previously created sets. When you imported this modified .inp file back to CAE materials and sections disapperared. Is that right ? If yes then there’s probably some misplaced keyword in your modified input file. Didn’t you get any warnings when importing input file to CAE ?
thanks @FEA way, I don't think there is keyword error and actually there is no warning... I have just uploaded the inp.file
I've imported the .inp and it worked fine. Everything important was there. Then I've submitted a datacheck from within A/CAE and it finished successfully.
I reviewed this file too and indeed it's correct. So you must have made some mistake when importing it to CAE. Maybe you accidentally chose different file or switched to different model. Remember that when you import model from input file to CAE then new model is created in the model tree while the old one remains unchanged and active.
thanks @Mustaine3 @FEA way!
Solved! I imported part by mistake...
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
