the sets in inp.file
NEROOO
36
So you created part, partitioned it and meshed it in Abaqus/CAE and exported .inp file. Then you defined sets, added material definitions and sections with these materials assigned to previously created sets. When you imported this modified .inp file back to CAE materials and sections disapperared. Is that right ? If yes then there’s probably some misplaced keyword in your modified input file. Didn’t you get any warnings when importing input file to CAE ?
thanks @FEA way, I don't think there is keyword error and actually there is no warning... I have just uploaded the inp.file
I've imported the .inp and it worked fine. Everything important was there. Then I've submitted a datacheck from within A/CAE and it finished successfully.
I reviewed this file too and indeed it's correct. So you must have made some mistake when importing it to CAE. Maybe you accidentally chose different file or switched to different model. Remember that when you import model from input file to CAE then new model is created in the model tree while the old one remains unchanged and active.
thanks @Mustaine3 @FEA way!
Solved! I imported part by mistake...
