Global Tie Constraint
I have an assembly made up of lots of small parts. Is there a way to set a general tie constraint for all contacting faces instead of making lots of individual tie constraints for each face?
RE: Global Tie Constraint
You can use Find Contact Pairs tool to automatically find all contacting faces. Then change Type for all pairs to Tie constraint using the same tool.
You can try this workaround:
Create a contact property with the behaviors Friction=Rough in tangential and No Separation in normal direction. Then define a General Contact and assign this behavior globally.
But be aware, that this only works when the faces are actually in contact. There is no Position Tolerance like in a Tie. But you can close small initial gaps when you create Contact Initialization definitions and global assignment.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
