Size of Openings in Skirt
Dear all,
Can anyone help me decide the nominal hole size for a skirt access in a skirt of height 4'-0"?
RE: Size of Openings in Skirt
Opening in skirt may be circular, oval, etc.
“See Pressure Vessel Design Manual”, by D. Moss and “Presuure Vessel Design Handbook”, by Bednar
Also as Tailing Trunnion:
Utilizes reinforced openings in skirt with through pipe. Pipe is removed after erection and the openings used as
skirt manways.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
