Hydraulic Circuit Fluid Temperature
My manager has shown me this circuit its for a welding station for my revision. Its a circuit hes ran for many years thats never had problems but all of a sudden the oil tank is very hot on inspection and the system seems to be losing its ability to work. Hes asked me why and what improvements can be done? I have never done hydraulics before so just learning. Many of the findings in theory state its due to filters clogging over time or leak but the oil level in the tank is fine and theres no contamination so that makes me believe that the filters are not clogged and theres no leakage.
The cylinder (item 10 )operated and holds the pressure to 100 bar for 15 mins and the relief valve is set to 130 bar. Pressure switch (item 11) is set at 100 bar. when pressure is required the PLC energises item 6 and when pressure has reached 100 bar the PLC signals item 6 to unload the pump.
I am assuming that the increase of temperature is a result of an increase in pressure due to heat not being able to dissipate in the system. Is it possibly because the switch has failed to indicate the pressure has increased from 100bar and as such the PLC has not activated the 2 position directional control valve (item 6) to unload the system and due to the oil not being able to flow anywhere as a result of the non return valve (item 7) the system is just wasting oil.
The pump is a fixed displacement gear pump that is displacing at 2.5lt/min.
Item 1 is a strainer and item 4 is a pressure filter with by-pas which opens at 1 bar. Item 8 is a accumulator. Item 5 is a 2 stage pressure relieve valve.
Any thoughts on what could of caused this heat increase?
RE: Hydraulic Circuit Fluid Temperature
It is most likely that some component is leaking internally, allowing high pressure oil to do no external work and converting that pressure drop into heat. Check each component to see which is hot, starting at the pump. If this is a valve block, you may have to contact a hydraulics supplier or engineer to specifically inspect for worn items. One delightful option is that cavitation inside a valve can produce extra flow paths and will only be discovered with a complete teardown and careful inspection.
It is possible the filters are clogged, but I would expect them to blow out if they offered much resistance to flow.
If it is because a pressure switch has failed then the related pressure relief valve will be extremely hot.
Have you actually pulled the strainer and confirmed it's not clogged?
Was the fluid changed recently to a different brand/spec fluid?
Is the pump running more than normal inputting heat to the fluid?
What is Item 2/3? It appears the strainer you speak of is at a deadleg/low point. Could debris be in other parts of the line (has operating pressure increased?)
Most likely, valve 6 or 9 are leaking high pressure oil to drain. The leaking line should be warmer than the other other lines. But the pump could also just be worn out. This would cause the oil supply line to be warmer than the reservoir temperature.
I was thinking it was a result of the cavitation as you say.
I haven't pulled the strainer no. Only the oil the oil reservoir is so hot that you wasn't able to touch it and normally its at ambient temperature. The oil level was checked and its at correct level and the regular oil sample checks showed no contamination.
Fluid wasn't changed recently.
Item 2 = fixed displacement gear pump
item 3 = Fixed speed motor
if item 6/9 leaked internally would the oil reservoir still be at normal level?
Valve 6 will not unload the pump. It is downstream of the relief valve 5. When 6 is energized the valve blocks flow.
When valve 6 is open it can only flow oil if the relief valve opens. Then the pump is being bypassed at the relief valve pressure and generating heat.
The bypass valve should be upstream of the relief valve and connected to tank and be normally closed to only opened by the plc signal. The relief valve should only protect the system from overpressure.
Maybe the diagram is incorrect.
Ted
When I say cavitation - I mean it has eroded through a valve block body, not just the presence of cavitation.
Internal leakage returns to the tank. External leakage ends up on the floor.
Yes - that location of the unload valve makes no sense. If valve 6 could block the flow out of 5 then the relief valve could never open.
That could be the case as my manager suggested any improvements to the circuit.
Did your manager intend for valve 6 to actuate the relief valve by blocking a port on the relief when valve 6 receives the plc signal?
Ted
As others have said, my first thought is that high pressure oil is being bypassed to the tank somewhere (this could also explain why "the system seems to be losing its ability to work") . Run the machine for a bit and let it get hot, then start checking valves and lines for one that is significantly hotter than the others. An IR camera is best for this, but if you don't have one an IR thermometer works well too; the back of your hand works in a pinch if you're very careful not to burn yourself. Checking the suction strainer before you do this wouldn't be a bad idea either.
As a sidenote since you're new to hydraulics: since your circuit has an accumulator (item 8), it can store hazardous energy which could cause injury when working on it if you don't take the right steps to bring the machine to a zero energy state. Since valve 9 is an open center valve, it should vent this stored pressure to tank once the machine is turned off, but you still need to verify zero energy before working on it (if valve 9 sticks, it would cause the system to hold pressure for example). If you trust both of the gauges on the circuit, checking that they read 0 should work fine.
Thanks guys I have understood the problem based on your replies. I think he is trying to trick me with the position of valve 6 as you suggested and purposely drawn the circuit incorrect.
I didn't notice that currently as the circuit is drawn the only way to unload the system is at pressure relief valve at item 5 since valve 6 cant unload unless the pressure relief valve 5 is open. So this indicates that the system can only unload when pressure is reached at "pressure relief valve pressure of 130 bar" which is causing the motor to be bypassed at a pressure of the pressure relief valve this in turn causes an overheat to the system. I believe as you say the circuit is drawn wrong and that valve 6 should be downstream.
It confused me cause he said it was ran fine for many years but i presume this was to trick me into believing it was internal leakage but the accumulator should account for this or for example filter blocks.
many thanks for the help i understanding.
Do you know what internal leakage is?
Disconnect rod side hose by the directional valve #9 and check of oil is coming out when piston is in extension force. Repeat on the capped side and retraction force. If oil is coming out in large amount the Piston seal are leaking and that causes the the heat.
The accumulator is there to hold piston pressurized while pump is unloaded.
Question:
How often is pump recharging the accumulator during the 15 min cycle?
That recharging cycle time is basically the measurement of system efficiency or internal leakage.
It would seem that valve 6 should open the valve 5 vent to tank to make valve 5 open and unload the pump. Closing the vent would make valve 5 open at the set relief pressure, causing heat.
Ted
It's also not surprising that valve 6 is as shown in the schematic. Energise it to build pressure (blocking relief of valve 5, causing it to close).
What's the pressure gauge just after the pump outlet show when it is supposed to be unloaded?
But why would you want to build pressure to pressure relieve valve pressure? Wouldn't this just heat up the whole system.
Uh oh ...
There should be very little flow through valve 6. It is a pilot signal to valve 5, which is the main relief/bypass. The pilot valve (6) is normally-open (energise to close) so that the "default" condition of the circuit is to vent flow from the pump through valve 5. You have to energise something in order to get pressure output, and if the energisation fails for some reason then it defaults to not having pressure. Usually this is the "safe" condition - it defaults to the "safe" condition, i.e. not moving, not clamping, not pressurising.
When valve 6 is open (default, spring-loaded condition, not energised) then there is nothing aside from perhaps the spring-loading preventing valve 5 (relief) spool from shuttling open. Follow the pilot signal on the other side of it. The slightest bit of upstream pressure pushes valve 5 spool towards opening, against the spring setting, and this is what lets the main flow go through.
When valve 6 is closed (energised) pilot relief from valve 5 is blocked, which prevents valve 5 from opening, which leads to the pump producing pressure that is sent on to the rest of the system. In reality the simplified schematic for valve 5 probably doesn't show all of its internal details. In this mode of operation it probably still acts as a relief valve but at a higher pressure. Only way to know that is to track down the exact specifications for this valve from its manufacturer and go into the details of what it does internally.
In the circuit that you have here, there should be hardly any pressure at the pump outlet gauge when valve 6 is not energised. If there is, the pump is expending work to produce that pressure and it is getting lost (turning into heat) through the relief valve.
So ... check it. ALL of it.
It will probably be easiest to start at the output end of the circuit and work backwards towards the inputs. Start with that pressure gauge at the pump outlet (before check valve 7). When the clamps are moving and clamping, does it read the same as the one after check valve 7? It should (it will of course really be slightly higher by the pressure drop through check valve 7 itself, but this should be minimal). Then the gauges should go up as the accumulator fills until it reaches the pressure switch setting, at which point the pressure gauge after the check valve should stay put, and the pressure gauge before the check valve should drop to almost nil, and it should stay like that for quite a long time (since there should be no fluid demand on the system).
Is that what happens? If not, what's different?
Thankyou i didnt realise the use of valve 6 until i understood that it is working as a pilot signal to valve 5. I was assuming it was in the wrong place.
So i presume a combination of what you have suggested and the rest about internal leaking etc could be the possible reason why the oil reservoir is too hot to touch all of a sudden after the circuit was working fine for years.
My manager also asked if i could provide any improvements to the circuit? If the circuit is working fine for many years apart from this odd occasion of heat generation what can improve it apart from the common sense of better technological advanced equipment?
I appreciate the comments in helping me understand hydraulics.
If design intent and basic functionality is correct (and evidently, it has been for years) don't start trying to improve until you first find and fix what's wrong.
Is the piston seal leaking during the 15 minute hold portion of the cycle?
What do you mean by the system losing its ability to work? What is it doing or not doing and when?
Ted
This is a case study provided by my manager to help me learn hydraulics and understand. I think he just wants general reasons as to why the oil reservoir is overheating in the current circuit as shown. He simply just gave me this circuit and said the system has worked for many years but one morning he came and the oil reservoir was so hot he wasn't able to touch it (this is not the normal state) and asked me what are the possible causes of the problem? Then he mentioned to suggest any improvements to the circuit that might protect against the in the future but do not suggest major hydraulic changes since the circuit is standard unloading circuit that has worked well for many years.
The only other info given was as stated above
the cylinder (10) is of a clamping station that holds nominal pressure of 100 bar for approx 15 min then off for 2 mins while welded piece is removed and recharged with unwelded pieces. The relief valve (5) is set to 130 bar. When pressure is required the PLC energises Item 6 and when the correct clamp pressure has been achieved, the pressure switch detects system pressure as correct and sends a signal by the PLC to valve 6 to unload the pump. Also during the 15 mins welding, if pressure switch (11) sees a pressure drop below the 100 bar, valve 6 is re-energised until the correct pressure is regained.
He said that the oil level is fine and regular oil sample checks show no issues of contamination. The system sees to be losing its capability to work no other information.
He said to come back to me with the possible causes of the problem.
Which i think everyone has stated it can be a multiple set of things which i need to list to him.
"Trust, but verify" is extremely important when you're troubleshooting. From the way your posts have been written, it sounds like you've done a lot of trusting, but no verifying. You really need to go out to this machine, watch it run and start checking things for yourself. For instance, is valve 5 actually set to 130 bar, or is it maybe only set to 110 bar? During the 15 minute clamp time, what does each pressure gauge read? Does the accumulator have to be recharged during the 15 minutes? If so, how often? Can you tell where the heat is being generated (which component is the hottest)? Have you talked to anyone else besides your boss that might be able to confirm or maybe counter your boss's description (maybe it's always run like this and your boss has only just noticed it)? When your boss says that oil samples show no issues of contamination, what does that mean exactly and when was the last sample taken?
This isn't a problem that is easily solved at your desk, go out to the machine and poke around a bit. If you're too new/inexperienced to do this safely by yourself, get a list of things you want to check (you have enough info in this thread to make a pretty good list) and find someone who can help you out. If there are any good maintenance people at your company, I'd recommend making friends and seeing if they can help you out.
Stick - the machine does not exist. It was to test if the OP knew about hydraulics.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
Modern cars, trucks, and other vehicles feature an ever-increasing number of sophisticated electrical and electronic features, placing a larger burden on the wiring harness that enables these new features. As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - Modeling and Optimizing Wire Harness Costs for Variation Complexity
This paper will focus on the quantification of the complexity related costs in harness variations in order to model them, allowing automated algorithms to optimize for these costs. A number of real world examples will be provided as well. Since no two businesses are alike, it is the aim of this paper to provide the foundational knowledge and methodology so the reader can assess their own business to model how variation complexity costs affect their business. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
