Hello Forum,
Can we design a body flange with manway clamps instead of bolts for clamping, using ASME Sec VIII Div 1, mand appdx 2?
Note: Sealing material - non metallic o rings.
IMO, Bolt PCD shall be replaced by the PCD of clamp contact centre
But where we can find the allowable stress values required for flange calculations, for the clamp material designated / identified by manufacturer as SS 304 for example.
How will you face this situation.
Please do share your opinion.
Thank you in advance.
GD_P
GD_P
