hello every one. this is amando m
mugiri amando
1
hello every one.
this is amando mugiri. i wish to be guided on challenges i should address when programing a software for designing, and optimizing concrete materials for septic tanks.
thank you.
1. Choose the proper concrete mix so chemical interaction is minimized.
2. Provide corrosion protection for any rebar.
Mike McCann, PE, SE (WA, HI)
4. Water stops at cold joints.
Read ACI Manual of Practice....all volumes. It will give you everything you need.
