Struggling to stop pump leakage. Please advise if you have hydraulic/pneumatic experience / expertis
We have a reciprocating pump that feeds off 2 gear pumps with highly viscous sealer. There is one line coming off of the main reciprocating pump, tees off at the front gear pump and goes another 20ft to the rear gear pump. The reciprocating pump works at the same frequency throughout the cycle of 30 seconds from start to finish. The problem is, the rear gear pump finishes its job 5 seconds earlier than the front gear pump. Looks like, as soon as the rear gear pump closes, all the flow is directed to the front gear pump which increases the internal pressure and causes the sealer to leak out of the shaft seals. We have had sealer leakage out of front gear pump since we installed it. We can't reduce the rate/pressure of the reciprocating pump as it would starve the system. If I put pressure regulators just before each gear pump, would that prevent pressure surge at the front pump after rear is done ahead of time? Or do I need to put flow control valves to limit amount of sealer going into both gear pumps? If I put flow control valves, and reciprocating sealer pump is working at the same rate, how do I protect the system from destroying itself? I can't put pressure release valve on a line full of sealer… How do you think this leakage can be prevented?
RE: Struggling to stop pump leakage. Please advise if you have hydraulic/pneumatic experience / expertis
Any chance you can scratch this out on a napkin including every detail you can think of? Take a picture of it and post it in here? Better info, better answers. Use the little Camera Image Icon for a direct insert into the post.
Keith Cress
Can you put a higher pressure capacity seal in the pump?
Ted
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
