Manganese value is more
Dear all,
We have LTCS Pipe(18" 160 sch A333 GR. 6), completed the flattening test. In the chemical analysis report shows manganese composition value is 1.49 but the range is between. 290 to 1.06
Shal we accept dis. Experts share your opinions
RE: Manganese value is more
Do you own a copy of A/SA 333? Read note A on Table 1. You're clearly above the limit of note A.
Is the Mn composition on the suppliers CMTR or was this a check that you performed? If the latter, what method was used to perform the check?
Also, I don't have the -18 revision of the standard but I doubt it has changed, on the chemistry table there is a footnote for grade 6 that allows Mn up to 1.35% depending on the carbon content.
Bob
And there is the additional tolerance on a check chemistry.
Though like Bob I am more concerned with how you measured it.
Ed,
I initially expected the same thing on the product analysis. I worked to the casting specs for years and A703 has the additional tolerances for a product analysis.
Unless it was changed in the -18 version A333 references A999. For product analysis A999 kicks you back to the material standard, the chemical testing standard A751 does not include product analysis tolerances either. A333 has a method if the product analysis if requested on the PO to be done by the supplier but does not mention a product analysis done by the purchaser. A333 does not provide extended tolerances for the product analysis. Unless there are other standards that they are working to it looks like any product analysis would need to meet the chemical requirements in A333.
Bob
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
