Contact US
shaft Fit to Spherical Roller bearing
Bearing Replacement:
Two split block bearing use for Force Draft Fan
measuring shaft OD = 69.97 mm
spherical roller bearing 22214E/C3 use on Split Roller bearing.
what is the clearance between the shaft and Inner race for Spherical Roller bearing?
RE: shaft Fit to Spherical Roller bearing
If the 70mm shaft is rotating, it should be a shrink fit to the bearing inner race or else it will rattle around and wear the shaft.
69.97mm sounds like a worn shaft. Maybe you can get away with a line-to-line fit and very tight axial compression with a locknut.
The manufacturer's website should have that information. If it happens to be an SKF bearing, poking around here or here should give you the info that you need.
As others said, NO clearance based on your description of your application.
What is the part number of the bearing stamped or etched on the face of one of the bearing races/inner rings?
Your attached image shows a taper bore bearing with a tapered adapter.
Depending on manufacturer, that style might have a "K" in the part number.
https://www.skf.com/us/products/bearings-units-hou...
Actually , the bearing install on shaft without sleeve.
Bearing type: spherical roller bearing
Bearing No. 22214E/C3
My question about diameter shaft what is min/max to be tight fit with bearing?
I attached similar picture of split bearing but it’s without adapter beqring directly install on shaft.
Q2- how to inspect bearing housing?
Q3- how to determine life of spherical roller bearing to avoid any breakdown?
Q4- what do you think the reason for worn shaft and bearing inner race found loose?
The issue happened 10 days after preventive maintenance performed ( oil changed) vibration and noise observed.
Q5- what is the best method to repair shaft ? If the shaft reduce 0.2 mm
Q1 and Q3 reference bearing manufactures manuals etc
Q2 Use Machinist measuring tools micrometers or Plastigauge / SKF or other bearing suppliers will list housing dimensions
Q4 Without details pictures etc, It could be anything.
Q5 Options: New shaft use adapter sleeves or Belzona ( use and opinions very / personally I don't care for it) There are other options, but this is what I thought of first.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
