NX REFERENCE SETS 1
flitch1969
Automotive
Every time i create sheets, solid bodies, etc they get put into the reference sets. i dont want them put into the reference sets. i will manually put them in when i'm ready. Where is the toggle to turn this off.
thanks
DAVE
Customer defaults -> Assemblies -> site standards -> reference sets -> model reference set, no automation.
This option will prevent new solids and sheets from being automatically added to the model ref set while you are working in the context of the component part file (part file = display and work part).
If you are working in the context of an assembly (assembly = display part, component = work part), then new geometry created will be added to the currently used ref set. If this is undesired, try changing to the "entire part" ref set before creating new geometry.
www.nxjournaling.com
