Rated Cv of Valve
Sid89
41
Hello everyone. I am new to the Valve Engineering profession. I would like to know:
How to calculate the rated Cv of a valve with a full port ball and V-port ball?
I need to know the mathematical/analytical method of calculating the rated Cv.
Syed
Cv is a measure of flow rate (GPM) of 60F water at various positions of valve travel.
The method is an empirical test via installing the valve in a flow rig and running the test.
