Abaqus scripting
harshacamso
BE
I am anew user for abaqus scripting. I created a set in Cae file. then I opened rpy file. it is,
elements1 = e1.getSequenceFromMask(mask=('[#0:53 #8000000 ]', ), )
a.Set(elements=elements1, name='Set-3')
this, (mask=('[#0:53 #8000000 ] command is very difficult to understand. I checked in user manual. but it did not helped me a lot. infact I need to create sets for all elements by reading element's label. how do I replace this " FromMask(mask=('[#0:53 #8000000 ]" part with element label.
thank you
The reporting with these hashes is the default, because of performance reasons. But you can change that. Enter/paste the two command below into the A/CAE CLI and the reporting will be done with the index method during the session. So the IDs of the objects is used.
session.journalOptions.replayGeometry
session.journalOptions.setValues(replayGeometry=INDEX)
You can also add these two commands into an Abaqus environment file, to have them executed automatically at every start of Abaqus/CAE.
Code:
def onCaeStartup():
