Contact US
Compression only
Compression only
Compression only
Hi guys,
I am doing a response spectrum analysis, and I want some elements to carried compression loads only. I read from ETABS help that there is a feature that name Tension/Compression Limits but this option is working only for nonlinear analyses (mention in help menu). since the response spectrum analysis is a linear analysis. I would like to know, how can I make the elements to work only in compression using this analyses.
RE: Compression only
Response Spectra analysis is inherently a linear analysis. So, you can't have non-linear elements.
Note: Your stiffness will be linear as well for a response spectra analysis. Though, it may be based off of a non-linear load case that accounts for P-Delta softening.
What kind of compression only elements are you thinking of? Compression only soil springs?
If you are talking about tension or compression only members, in the past I've run a non-linear analysis with nominal lateral load to effectively remove one directions worth of members (usually roof or wall bracing). Then follow up with the RSA. Noting of course the results in terms of the forces are only valid for one direction of loading. Repeat for the other direction. Works best for tension only braces and structures with the same stiffness in both directions, but depending on your scenario may be totally inappropriate.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
