NX GRIP Print ENTITY data
miike110
thread561-221594
How do you print whatever is inside the entity?
print/myEntity(index) doesn't work
I am trying to debug a .grs program which calls several other .grs programs into memory.
One of the arguments passed into the .grs file that I am attempting to debug is myEntity.
There is a part in the program where a variable is set to a point/&spoint(myEntity(index))
I'd like to access whatever is being passed into the &spoint (start point) in order to make sure the correct data is in there.
Thank you!
Since that thread was never finished, not sure what that poster was looking for.
What are you looking for?
myEntity is an array, defined in the program code.
index is an entry into the array.
Depending on how the array is defined, that will get you the data type.
Index will get you the values from the array once you know the type and index value.
The array could be 1 dimensional, or 2 dimensional. 1 dimensional would be a single X, Y, Z point. 2 dimensional would be multiple points. in the same data statement.
Ben Loosli
In my case, "index" is being declared as a number type, yet I don't see it being set to anything.
It is referenced several times in Program Loops where:
Code:
do/LOOP1:,index,1,total_index
Anyways,
There is a line in .grs code that creates a point using an element from within the Entity array.
Code:
myPoint = point/&spoint(myEntity(index))
Can you help me write a block of code to output what is being passed into the point creation?
Code:
doesn't work.
The Entity is defined as a tag_t object on the C++ side. It is passed into the .grs file as a grip argument.
When I print out myEntity(index) on the C++ side inside a loop (before it gets passed into the .grs file as a grip argument), it shows 5 numbers that increments by 1 at the end of each loop.
However, each time I run the program, those 5 numbers change in the sequence of looping operations.
For example the first 10 sets of 5 digit numbers in one instance of running the program will not match the second 10 sets of 5 digit numbers when I re-run the same program (the tag_t object is set to a NULL_TAG inside a For Loop, so I'm guessing it's collecting some kind of data that changes in memory)
Hi Miike110,
At the beginning of the GRIP subroutine/program add a declaration for an array of 3 numbers to accept the data from the startpoint (&spoint) information of entity "myEnitity". The array is named "N". Change the name if this causes conflicts.
Code:
ENTITY/myEntity(5)
[b]Number/[highlight #FCE94F]N[/highlight](3)[/b]
Replace the "print/myEntity(index)" with the following lines to display the 3 values that are extracted from the entity.
Code:
print/'Index = ' + istr(index)
print/'Type = ' + istr(&TYPE(myEntity(index)))
[highlight #FCE94F]N[/highlight]=&SPOINT(myEntity(index))
print/fstr([highlight #FCE94F]N[/highlight](1))
print/fstr([highlight #FCE94F]N[/highlight](2))
print/fstr([highlight #FCE94F]N[/highlight](3))
Hope this helps,
Joe
