p-MLFD
rmunderw
Aerospace
I think there are multiple errors in the paper "a poly reference implementation of the maximum likelihood complex frequency domain estimator and some industrial applicatinos.pdf"
I have programmed up the LSCF, MLFD, and p-LSCF methods and am having trouble with the final piece p-MLFD. The dimensions of the matrices in the early part of the paper don't seem to be right and I think the definition of the X and Y matrices are swapped. The definitions of the R, S, T, V, & W matrices are mostly correct. I could be messing up the un-vec operator of delta vec(D) or delta vec(No). I believe the un-vec of a column array should be a 2 row or column matrix with one row/column being every other value in the vec array.
Has anyone tried to code this up?
 https://files.engineering.com/getfile.aspx?folder=e262d6a1-d01a-47e7-9018-487b74a87f06&file=_a_poly_reference_implementation_of_the_maximum_likelihood_complex_frequency_domain_estimator_and_some_industrial_applicatinos.pdf
I've written all of these in Python. The exact implementation of the un-vec is:
alpha[:,0:1] = alpha[:,0:1] + delta_a[::2]
alpha[:,1:2] = alpha[:,1:2] + delta_a[1::2]
the colon's inside the array dimensions are start:stop:step. The delta_a array is the vec'd array, so the length is twice as long as the first dimension of alpha.
