1) tiered retaining walls. Discussion in the office today yielded, the easiest way to analyse the tiered walls is to design the lower wall assuming it was retaining the full height. See sketch attached. This example has a lower wall height of 1.8m and a upper wall height of 0.9m, so design the lower wall for a retained height of 2.7m and design the upper wall for a retained height of 0.9m?
Is this overly conservative?
2) Same example as number 1, but what if the ground is falling away at 15 degrees. How would this change your design approach?
I'd agree with designing the front wall to be full height dependant, though it does depend on how far away it is. But given your proportions I can't see how you couldn't design for the entire height unless using something like wallap which most structural engineers don't have access to.
There was some NZ based advice on this published in a design example by MBIE a few years ago. I'll see if I can track it down for you.
Ok, I found what I was thinking of, it was not by MBIE, and was unfortunately related to timber pole retaining walls! (damn memory fail). Same principles probably apply to ensure no loading within the failure wedge though. Seems to be some anecdotal evidence on the net relating to being at least 2 times the height of the first wall to the second wall to avoid significant loading on the first wall from the second. But I think the rotation and settlement of the second wall are of particular concern in your arrangement where the 2nd overlaps the first.
In the situations you note I tend to prefer the following arrangement, not only are you not putting a wall within the 'fill' of the lower wall and possibility of settlement and wall rotation (quite important if on the boundary and trying to retain neighbouring property), there is also possibly less excavation, just design the back wall for the full height retaining and walk away. If it doesn't work as masonry, you can have stiffening pilasters on the uphill side or pour some section at the bottom in concrete with block on top.
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Metal 3D printing has rapidly emerged as a key technology in modern design and manufacturing, so it’s critical educational institutions include it in their curricula to avoid leaving students at a disadvantage as they enter the workforce. Download Now
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
RE: Tiered cantilevered block retaining walls
That would be appreciated
