Impact machine foundation
Anyone has a guideline or design example for a foundation for impact machine ? I have a die cast machine, the manufacturer is giving : Machine weight 155000 lb, the horizontal shake force at 140 RPM is 31500 lb and vertical shaking force is 15000 lb.
Thank you for helping
gasma1975
RE: Impact machine foundation
ACI 351.3 R-04 treats the subject. The bible of this kind of design is Design of Structures and Foundations for Vibrating Machines by Arya, et al.
By the way, (in case you haven't done this type of design before)......one tricky deal with it is it's effect on adjacent structures. This isn't your normal pump foundation or light compressor......this is almost like day to day pile vibrations. So keep this in mind.
I dug in some more tonight into a older reference: 'Dynamics of Bases and Foundations', by: Barkan (1962). Pretty much considered a classic in this line of work, it goes into the design of a impact base. (makes points you just don't see anymore.)
One drawback to it though: he is tying down the base to wood and so forth. (That was actually pretty common way back when.) Today the standard is more towards preloaded bolts [down to] a mat with a epoxy grout on the surface. Master builders/BASF has some of those types of details on their site. I think 5 Star does too.
Thank you for the help.
I also found on Google a great book with examples, "INDUSTRIAL MACHINES Handbook for Practising Engineers by KG Bhatia"
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
