Voltage transformer in GIS
How is it possible to have such small size voltage transformer within 220kV GIS?
If we consider the ratio--220kV/110V and the turns that needs to be wound 2000--it is huge--still how do manufacturers manage to put it in such a small enclosure.
RE: Voltage transformer in GIS
Quote (How is it possible to have such small size voltage transformer within 220kV GIS?)
The main reason is that the GIS is enclosed in SF6 and dielectric clearance is significantly reduced compared with air. The AIS VT must have a large bushing to maintain the clearance between the energized part on top (xx kV) and the base tank at ground potential (V=0).
See the illustration below.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
