Charpy Impact Testing
Ladies & Gentlemen:
I would like to get your opinion on the following matter:
I am using Inco 82 weld wire (ERNiCr-3)for welding SA 240 405 Stainless Steel material, which is a ferritic chromium stainless steel and the base metal is required to be impact tested per UHA-51(d)(3)(b). The impact testing of the PQR is also required per UHA-51(e). Is impact testing of the vessel plates required per UHA-51(f)?
Thank you in advance,
Siva Nair
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
