WHat does this P&ID symbol mean?
RE: WHat does this P&ID symbol mean?
Do you think you can find another set of drawings around the same age that has the legend sheet? If you can describe what that pressure control loop is meant to do and what type of process this is, maybe someone that has worked with something similar can give their thoughts.
My guess is that the PIC has an interlock at some defined low pressure, so therefore an "L" is shown. But again, complete guess.
you should show more than the symbols. Show a good portion of the drawing with the title block and notations, the we may have a better idea to the meaning of the symbols.
That is local a pneumatic controller and valve, with an instrument air suppliy for the controller to directly modulate the valve.
Common symbols in the older plants.
The "L" is for "LOW" and is related to the "PCV" (Low Pressure Control Valve) and the "PIC" (Low Pressure Indicating Controller).
Sometimes its possible to do all the right things and still get bad results
So does it mean that it is a symbol for "LOW" alarm/trip?
@OP i think the conclusion is that it can mean a lot of things and that you will need to look at a legend or some other P&ID where its also used (and not used).
My best guess would be as hacksaw, self actuating valve but i would guess that the L symbol could mean that the SP is adjustable - maybe remotely adjustable? Maybe its a hacksaw says that its a plant air supply, if you have a high presure and a low pressure plant air system then the L would support this (meaning air from the low pressure system).
I always though it just indicates a supply of instrument air.
BasakAbhishek,
I am happy that you found the actual definition for the actual symbol for that specific Project.
I assume you found the actual P&ID Legend Sheet for that specific Project.
Having that symbol and using it for that specific purpose does not mean that some other Project, by a different Process Engineer, might use that symbol and the letter "L" for some other purpose.
Make sure that all your projects have a "P&ID Legend Sheet" with all Symbols identified.
smile So its a very good example that a symbol can have many meanings and that they will all make sense even though they can be very different!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
