Minimum Ceiling Height of Steel Structure to Require Fireproofing
cgseso
PH
I believe that if the framing plan of the second floor of a steel building is relatively high (so high that it cannot be reached when) there really is no need for it to be fireproofed. Is there a code/ regulation that can support this claim? Anyone who has experienced on this? Will be glad to hear your thoughts.
You should repost this here: forum179
faq731-376
