Contact US
Flare Bevel Weld "Effective Area"
Hi Everyone
We are field welding a HSS2x2x1/4 to a HSS8x8x1/4, flat part of HSS8x8 only. The AISC manual shows the "Effective Throat" for flare groove in Table J2.2. If we use 5/8R where R=2t, this becomes 5/8*2*(1/4)=5/16". This is the "effective throat". However, the weld strength based on equation J2-3 is Rn=Fnw*Awe; Awe is shown on Table J2.5.
For Tension Normal to weld axis, Table J2.5 shows Fnw = 0.60Fexx, Awe in inches^2 as "See J2.1a".
My question is - how do you figure the Effective Area, Awe, using the "Effective Throat" from J2.2 or J2.1a? Which do we use, J2.1a or J2.2?
Thanks!
RE: Flare Bevel Weld "Effective Area"
Multiply the effective throat times the effective length of the weld?
If I understand your configuration correctly, the smaller HSS is lapped on the flat portion of the larger HSS. The welds are flare bevel along the length, thus no actual beveling of the HSS's takes place. Seems Table J2.2 would be applicable, J2.1 and J2.1 are for Partial Joint Penetration which would require some beveling of the parts (HSS's).
All I know is P/A and Mc/I
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
