Girt Web check
Girt Web check
Girt Web check
I was reviewing this guy's calcs for girts.....and he didn't do a web check for the girt dead load transfer to the sag rod. (Putting bending stress in the web.) That's something I've always done (even though it typically is minimal for rolled shapes). He thinks it's overkill to check....do you normally check it for rolled shapes?
RE: Girt Web check
Rightly or wrongly, it's not something I've worried about in the past.
HELP! I'd like your help with a thread that I was forced to move to the business issues section where it will surely be seen by next to nobody that matters to me: http://www.eng-tips.com/viewthread.cfm?qid=456235
RE: Girt Web check
@ Kootk: thanks.
@BAretired: I agree. But I'm not talking about bracing.....just the (self-weight) transfer to the sag rod.
RE: Girt Web check
Once upon a time, I did use sag rods. But never checked the web local stress.
RE: Girt Web check
@WARose: Not too sure how you would check the self-weight transfer. The worst case would be the uppermost girt where the sag rod supports all of the girts in the curtain wall. That could be significant in very tall curtain walls. Bending in the web would depend on the spacing between sag rods above and below the girt being checked.
Do you perform a yield line analysis on the web of the girt? Have you ever found this to be critical?
BA
RE: Girt Web check
The sag in girts should be resisted by a stiff member at the top, not just by another girt. Another way is to use struts instead of ties, so the sag is resisted at the bottom.
RE: Girt Web check
Never checked it.
Sag rod hang from something stiff up the top.
RE: Girt Web check
I have always checked the girt for weak axis bending between sag rods but not for any local effects on the web.
RE: Girt Web check
Nope. Just a regular elastic calculation/model.
Not for a AISC shape.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
White Paper - The Criticality of the E/E Architecture
Modern vehicles are highly sophisticated systems incorporating electrical, electronic, software and mechanical components. Mechanical systems are giving way to advanced software and electronic devices, driving automakers to innovate and differentiate their vehicles via the electric and electronic (E/E) architecture. As the pace of change accelerates, automotive companies need to evolve their development processes to deliver and maximize the value of these architectures. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
