SEBASTIANOFA
Automotive
Hello to all, thinking about car chassis, when it is used we should not always have corrosion due to fatigue at the welding points since they are points of high stress that often do not have a fatigue limit? shouldn't they show micro cracks that will corrode in a short time? I think the coating will not protect from this type of corrosion. what's the difference with stress corrosion? Will stress corrosion also occur for static loads at room temperature?
if anyone could explain these things to me I would be grateful
if instead a car is kept still but it already has some micro fractures in the welding points that are however protected by the paint, these will corrode even with only a static weight
